Por favor, alguém saberia me dizer o motivo do meu DHT11 estar retornando Umidade e Temperatura = 0 ? Está linkado com o ThingSpeak para receber os dados em gráfico. #include <SoftwareSerial.h> #include <dht11.h> #define RX 2 #define TX 3 #define dht_apin 11 // Analog Pin sensor is connected to dht11 dhtObject; String AP = "REDE WIFI"; // AP NAME String PASS = "SENHA WIFI"; // AP PASSWORD String API = "MZ6VXUM0LIVPAOS5"; // Write API KEY String HOST = "api.thingspeak.com"; String PORT = "80"; int countTrueCommand; int countTimeCommand; boolean found = false; int valSensor = 1; SoftwareSerial esp8266(RX,TX); void setup() { Serial.begin(9600); esp8266.begin(115200); sendCommand("AT",5,"OK"); sendCommand("AT+CWMODE=1",5,"OK"); sendCommand("AT+CWJAP=\""+ AP +"\",\""+ PASS +"\"",20,"OK"); } void loop() { String getData = "GET /update?api_key="+ API +"&field1="+getTemperatureValue()+"&field2="+getHumidityValue(); delay(1500); sendCommand("AT+CIPMUX=1",5,"OK"); delay(50); sendCommand("AT+CIPSTART=0,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK"); delay(50); sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">"); delay(500); esp8266.println(getData); delay(1500); countTrueCommand++; delay(50); sendCommand("AT+CIPCLOSE=0",5,"OK"); delay(50); } String getTemperatureValue(){ dhtObject.read(dht_apin); Serial.print(" Temperature(C)= "); int temp = dhtObject.temperature; Serial.println(temp); delay(50); return String(temp); } String getHumidityValue(){ dhtObject.read(dht_apin); Serial.print(" Humidity in %= "); int humidity = dhtObject.humidity; Serial.println(humidity); delay(50); return String(humidity); } void sendCommand(String command, int maxTime, char readReplay[]) { Serial.print(countTrueCommand); Serial.print(". at command => "); Serial.print(command); Serial.print(" "); while(countTimeCommand < (maxTime*1)) { esp8266.println(command);//at+cipsend if(esp8266.find(readReplay))//ok { found = true; break; } countTimeCommand++; } if(found == true) { Serial.println("OYI"); countTrueCommand++; countTimeCommand = 0; } if(found == false) { Serial.println("Fail"); countTrueCommand = 0; countTimeCommand = 0; } found = false; } ============================================================================== Está retornando: 13:09:29.526 -> 3. at command => AT+CIPMUX=1 OYI 13:09:30.586 -> 4. at command => AT+CIPSTART=0,"TCP","api.thingspeak.com",80 OYI 13:09:30.818 -> 5. at command => AT+CIPSEND=0,58 OYI 13:09:32.856 -> 7. at command => AT+CIPCLOSE=0 OYI 13:09:33.183 -> Humidity in %= 0 13:09:33.215 -> Temperature(C)= 0
