jeffrancisco_1
jeffrancisco_1
Mensagem Sex Jan 22, 2021 5:54 pm
TENTANDO COMPILAR Ardbir em M5StickC Plus ou outra ESP32...
Boa tarde...
Estou tentando fazer um projeto de ARDBIR porém não queria realizar ele em placa de ARDUINO, gostaria de fazer com uma placa baseada em ESP32 pela própria possibilidade de integração com a internet que facilitaria enormemente a automação:
Tentei compilar direto para a placa M5StickC Plus, eis o relatório de erros:
ENVIEI CÓDIGOS FONTE NO ANEXO...
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Placa:"M5Stick-C, Default, 1500000, None"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\User\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\User\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp32:esp32:m5stick-c:PartitionScheme=default,UploadSpeed=1500000,DebugLevel=none -ide-version=10813 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_921154 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_694653 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\esptool_py\2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\esptool_py\2.6.1 -verbose C:\Users\User\Downloads\PROGRAMAÇÃO\Ardbir\Open-ArdBir-master\Open-ArdBir\Open-ArdBir.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\User\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\User\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp32:esp32:m5stick-c:PartitionScheme=default,UploadSpeed=1500000,DebugLevel=none -ide-version=10813 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_921154 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_694653 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\esptool_py\2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=C:\Users\User\Documents\ArduinoData\packages\esp32\tools\esptool_py\2.6.1 -verbose C:\Users\User\Downloads\PROGRAMAÇÃO\Ardbir\Open-ArdBir-master\Open-ArdBir\Open-ArdBir.ino
Using board 'm5stick-c' from platform in folder: C:\Users\User\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.4
Using core 'esp32' from platform in folder: C:\Users\User\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.4
Detecting libraries used...
"C:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/config" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_trace" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_update" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/asio" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bootloader_support" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/coap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/console" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/driver" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-tls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_event" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_client" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_server" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ethernet" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/expat" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fatfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freemodbus" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freertos" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/heap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/idf_test" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/jsmn" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/json" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/libsodium" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/log" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/lwip" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mbedtls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mdns" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/micro-ecc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mqtt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/newlib" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nghttp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nvs_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/openssl" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protobuf-c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protocomm" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/pthread" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/sdmmc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/soc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spi_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spiffs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcp_transport" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ulp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/vfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wear_levelling" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32-camera" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -C -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5Stick_C -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5Stick_C\"" "-DARDUINO_VARIANT=\"m5stick_c\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\cores\\esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\variants\\m5stick_c" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_921154\\sketch\\Open-ArdBir.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for EEPROM.h: [EEPROM@1.0.3]
ResolveLibrary(EEPROM.h)
  -> candidates: [EEPROM@1.0.3]
"C:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/config" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_trace" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_update" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/asio" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bootloader_support" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/coap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/console" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/driver" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-tls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_event" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_client" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_server" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ethernet" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/expat" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fatfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freemodbus" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freertos" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/heap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/idf_test" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/jsmn" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/json" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/libsodium" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/log" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/lwip" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mbedtls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mdns" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/micro-ecc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mqtt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/newlib" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nghttp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nvs_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/openssl" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protobuf-c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protocomm" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/pthread" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/sdmmc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/soc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spi_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spiffs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcp_transport" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ulp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/vfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wear_levelling" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32-camera" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -C -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5Stick_C -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5Stick_C\"" "-DARDUINO_VARIANT=\"m5stick_c\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\cores\\esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\variants\\m5stick_c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries\\EEPROM\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_921154\\sketch\\Open-ArdBir.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
  -> candidates: [LiquidCrystal@1.0.7]
"C:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/config" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_trace" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_update" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/asio" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bootloader_support" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/coap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/console" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/driver" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-tls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_event" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_client" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_server" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ethernet" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/expat" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fatfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freemodbus" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freertos" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/heap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/idf_test" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/jsmn" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/json" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/libsodium" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/log" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/lwip" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mbedtls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mdns" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/micro-ecc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mqtt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/newlib" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nghttp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nvs_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/openssl" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protobuf-c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protocomm" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/pthread" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/sdmmc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/soc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spi_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spiffs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcp_transport" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ulp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/vfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wear_levelling" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32-camera" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -C -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5Stick_C -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5Stick_C\"" "-DARDUINO_VARIANT=\"m5stick_c\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\cores\\esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\variants\\m5stick_c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries\\EEPROM\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_921154\\sketch\\Open-ArdBir.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for OneWire.h: [OneWire@2.3.5]
ResolveLibrary(OneWire.h)
  -> candidates: [OneWire@2.3.5]
"C:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/config" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_trace" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_update" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/asio" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bootloader_support" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/coap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/console" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/driver" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-tls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_event" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_client" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_server" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ethernet" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/expat" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fatfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freemodbus" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freertos" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/heap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/idf_test" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/jsmn" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/json" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/libsodium" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/log" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/lwip" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mbedtls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mdns" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/micro-ecc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mqtt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/newlib" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nghttp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nvs_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/openssl" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protobuf-c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protocomm" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/pthread" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/sdmmc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/soc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spi_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spiffs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcp_transport" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ulp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/vfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wear_levelling" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32-camera" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -C -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5Stick_C -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5Stick_C\"" "-DARDUINO_VARIANT=\"m5stick_c\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\cores\\esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\variants\\m5stick_c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries\\EEPROM\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\OneWire" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_921154\\sketch\\Open-ArdBir.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for PID_v1.h: [PID@1.2.0]
ResolveLibrary(PID_v1.h)
  -> candidates: [PID@1.2.0]
"C:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/config" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_trace" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_update" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/asio" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bootloader_support" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/coap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/console" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/driver" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-tls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_event" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_client" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_server" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ethernet" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/expat" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fatfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freemodbus" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freertos" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/heap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/idf_test" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/jsmn" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/json" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/libsodium" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/log" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/lwip" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mbedtls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mdns" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/micro-ecc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mqtt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/newlib" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nghttp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nvs_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/openssl" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protobuf-c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protocomm" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/pthread" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/sdmmc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/soc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spi_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spiffs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcp_transport" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ulp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/vfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wear_levelling" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32-camera" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -C -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5Stick_C -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5Stick_C\"" "-DARDUINO_VARIANT=\"m5stick_c\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\cores\\esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\variants\\m5stick_c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries\\EEPROM\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PID" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_921154\\sketch\\Open-ArdBir.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/config" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_trace" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/app_update" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/asio" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bootloader_support" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/bt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/coap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/console" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/driver" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-tls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_event" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_client" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_http_server" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ethernet" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/expat" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fatfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freemodbus" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/freertos" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/heap" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/idf_test" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/jsmn" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/json" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/libsodium" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/log" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/lwip" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mbedtls" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mdns" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/micro-ecc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/mqtt" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/newlib" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nghttp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/nvs_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/openssl" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protobuf-c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/protocomm" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/pthread" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/sdmmc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/soc" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spi_flash" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/spiffs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcp_transport" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/ulp" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/vfs" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wear_levelling" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp32-camera" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/esp-face" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -C -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5Stick_C -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5Stick_C\"" "-DARDUINO_VARIANT=\"m5stick_c\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\cores\\esp32" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\variants\\m5stick_c" "-IC:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries\\EEPROM\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PID" "C:\\Users\\User\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries\\EEPROM\\src\\EEPROM.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
