TwoWheels Road is a Two Wheels balancing robot created with LEGO NXT Technology. I've used only an Gyroscope sensor, with the bias correction based in X desplacement (drift). The stability comes from the computation speed, where doing in 10ms per cycle turns It very stable. I hope you like.Other projects: http://www.youtube.com/tarribas Tomás Arribas.
¡Olá Tomás! Welcome to the forum! Hope you enjoy it! Congratulations on the project, really amazing what is possible to do with one gyroscope and nice lines of code runing fast! Se lo desea, puede escribir en Español o Inglés. Pienso que muchos de los miembros de esta comunitad puedan entender sin problemas. Para los que no lo hacen, siempre hay traductor Google. Abrazos, Dudu Caio, Ele usou o controlador do Lego NXT. É aquele quadrado branco no meio do robô. Só um toque anglofônico 'What' é 'O que', 'Qual' é 'Which'Abração, Dudu
