Tibanamurilo
Tibanamurilo
Mensagem Qua Nov 06, 2019 4:56 pm
Recebendo o mesmo valor para o sensor HMC5883L
Oi gente!
Comecei recentemente a montar alguns projetos com arduino, e comprei o sensor HMC5883L para poder medir alguns campos magnéticos, mas ao rodar o código recebo sempre os mesmos valores.
Esse é o codigo que estou usando:
#include <Wire.h>
#include <HMC5883L.h>
HMC5883L compass;
int error = 0;
int ledpin = 13;
void setup()
  Serial.begin(9600);
pinMode(ledpin, OUTPUT);
  Serial.println("Starting the I2C interface.");
  Wire.begin(); // Start the I2C interface.
 Serial.println("Constructing new HMC5883L");
  compass = HMC5883L(); // Construct a new HMC5883 compass.
  Serial.println("Setting scale to +/- 1.3 Ga");
  error = compass.SetScale(1.3); // Set the scale of the compass.
  if(error != 0) // If there is an error, print it out.
    Serial.println(compass.GetErrorText(error));
  Serial.println("Setting measurement mode to continous.");
  error = compass.SetMeasurementMode(Measurement_Continuous); // Set the measurement mode to Continuous
void loop()
  MagnetometerRaw raw = compass.ReadRawAxis();
  MagnetometerScaled scaled = compass.ReadScaledAxis();
  int MilliGauss_OnThe_XAxis = scaled.XAxis;// (or YAxis, or ZAxis)
  float heading = atan2(scaled.YAxis, scaled.XAxis);
  float declinationAngle = 0.3764;
  heading += declinationAngle;
  if(heading < 0)
    heading += 2*PI;
  if(heading > 2*PI)
    heading -= 2*PI;
  float headingDegrees = heading * 180/M_PI;
  Output(raw, scaled, heading, headingDegrees);
void Output(MagnetometerRaw raw, MagnetometerScaled scaled, float heading, float headingDegrees)
   Serial.print("Raw:\t");
   Serial.print(raw.XAxis);
   Serial.print("   ");
   Serial.print(raw.YAxis);
   Serial.print("   ");
   Serial.print(raw.ZAxis);
   Serial.print("   \tScaled:\t");
   Serial.print(scaled.XAxis);
   Serial.print("   ");
   Serial.print(scaled.YAxis);
   Serial.print("   ");
   Serial.print(scaled.ZAxis);
   Serial.print("   \tHeading:\t");
   Serial.print(heading);
   Serial.print(" Radians   \t");
   Serial.print(headingDegrees);
   Serial.println(" Degrees   \t");
  delay(1000);
