luan_h_nogueira
luan_h_nogueira
Mensagem Dom Jul 29, 2018 7:16 pm
ALGUEM ME AJUDA A ACHAR O CONFLITO DO PINO 4 ?!
ESSE É O SKECTH, TEM UM CONFLITO NO PINO 4 E ELE NAO FUNCIONA E ATÉ AGR NAO CONSEGUI RESOLVER O PROBLEMA !! ALGUEM ME AJUDA
#include <Servo.h>
const int SPEEDO_PIN      = A0;
const int RPM_PIN         = A1;
const int FUEL_PIN        = A5;
const int LEFT_INDICATOR  = A2;
const int RIGHT_INDICATOR = A3;
const int PARKING_BREAK   = A4;
const int CRUISE_CONTROL  = 11;
const int FUEL_WARNING    = 12;
const int LOW_BEAM        = 0;
const int HIGH_BEAM       = 13;
int pinA = 9;
int pinB = 8;
int pinC = 7;
int pinD = 6;
int pinE = 5;
int pinF = 10;
int pinG = 3;
int pinH = 2;
// defines servo names
Servo speedo;
Servo rpm;
Servo fuel;
Servo cruise;
#define PACKET_SYNC 0xFF
#define PACKET_VER  2
#define SERVO_DIR_NORMAL false
#define SERVO_DIR_INVERT true
int serial_byte;
void setup()
  Serial.begin(115200);
  speedo.attach(SPEEDO_PIN);
  speedo.write(180);
  rpm.attach(RPM_PIN);
  rpm.write(180);
  fuel.attach(FUEL_PIN);
  fuel.write(170);
  cruise.write(180);
  pinMode(LEFT_INDICATOR, OUTPUT);
  pinMode(RIGHT_INDICATOR, OUTPUT);
  pinMode(PARKING_BREAK, OUTPUT);
  pinMode(FUEL_WARNING, OUTPUT);
  pinMode(CRUISE_CONTROL, OUTPUT);
  pinMode(LOW_BEAM, OUTPUT);
  pinMode(HIGH_BEAM, OUTPUT);
  pinMode(pinA, OUTPUT);
  pinMode(pinB, OUTPUT);
  pinMode(pinC, OUTPUT);
  pinMode(pinD, OUTPUT);
  pinMode(pinE, OUTPUT);
  pinMode(pinF, OUTPUT);
  pinMode(pinG, OUTPUT);
  pinMode(pinH, OUTPUT);
  //range-splitter LED's
  pinMode(22, OUTPUT);
  pinMode(24, OUTPUT);
  pinMode(26, OUTPUT);
  digitalWrite(LEFT_INDICATOR, 0);
  digitalWrite(RIGHT_INDICATOR, 0);
  digitalWrite(PARKING_BREAK, 0);
  digitalWrite(FUEL_WARNING, 0);
  digitalWrite(CRUISE_CONTROL, 0);
  digitalWrite(LOW_BEAM, 0);
  digitalWrite(HIGH_BEAM, 0);
  delay(500);
  speedo.write(0);
  rpm.write(0);
  fuel.write(0);
  digitalWrite(LEFT_INDICATOR, 1);
  digitalWrite(RIGHT_INDICATOR, 1);
  digitalWrite(PARKING_BREAK, 1);
  digitalWrite(FUEL_WARNING, 1);
  digitalWrite(CRUISE_CONTROL, 1);
  digitalWrite(LOW_BEAM, 1);
  digitalWrite(HIGH_BEAM, 1);
  digitalWrite(22, 1);
  digitalWrite(24, 1);
  digitalWrite(26, 1);
  delay(500);
  speedo.write(180);
  rpm.write(180);
  fuel.write(170);
  digitalWrite(22, 0);
  digitalWrite(24, 0);
  digitalWrite(26, 0);
  digitalWrite(pinA, HIGH);
  digitalWrite(pinB, HIGH);
  digitalWrite(pinC, HIGH);
  digitalWrite(pinD, HIGH);
  digitalWrite(pinE, HIGH);
  digitalWrite(pinF, HIGH);
  digitalWrite(pinG, HIGH);
  digitalWrite(pinH, HIGH);
  delay(1000);
void read_serial_byte_set_servo(Servo& servo, bool invert)
  serial_byte = Serial.read();
  serial_byte = (serial_byte < 0) ? 0 : ((serial_byte > 180) ? 180 : serial_byte);
  if (invert)
    servo.write(180 - serial_byte);
  else
    servo.write(serial_byte);
void read_serial_byte_set_servo_fuel(Servo& servo, bool invert)
  if (invert)
    servo.write(170 - serial_byte); //set lower than the tach and speedo to limit movement.
  else
void read_serial_byte_set_servo_cruise(Servo& servo, bool invert)
  if (invert)
    servo.write(180 - serial_byte); //set lower than the tach and speedo to limit movement.
  else
void skip_serial_byte()
  (void)Serial.read();
void digitalWriteFromBit(int port, int value, int shift)
  digitalWrite(port, (value >> shift) & 0x01);
void loop()
  if (Serial.available() < 16)
    return;
  if (serial_byte != PACKET_SYNC)
    return;
  if (serial_byte != PACKET_VER)
    //    lcd.clear();
    //   lcd.print("PROTOCOL VERSION ERROR");
    return;
  read_serial_byte_set_servo(speedo, SERVO_DIR_INVERT); // Speed
  read_serial_byte_set_servo(rpm, SERVO_DIR_INVERT); // RPM
  skip_serial_byte(); // Brake air pressure
  skip_serial_byte(); // Brake temperature
  read_serial_byte_set_servo_fuel(fuel, SERVO_DIR_NORMAL); // Fuel ratio
  skip_serial_byte(); // Oil pressure
  skip_serial_byte(); // Oil temperature
  skip_serial_byte(); // Water temperature
  skip_serial_byte(); // Battery voltage
  read_serial_byte_set_servo_cruise(cruise, SERVO_DIR_INVERT); // cruise speed, set to trip a light
  if (cruise.read() < 180)
  if (cruise.read() > 179)
  // Truck lights byte
  digitalWriteFromBit(LEFT_INDICATOR,  serial_byte, 5);
  digitalWriteFromBit(RIGHT_INDICATOR, serial_byte, 4);
  digitalWriteFromBit(LOW_BEAM,  serial_byte, 3);
  digitalWriteFromBit(HIGH_BEAM, serial_byte, 2);
  // Warning lights bytes
  digitalWriteFromBit(PARKING_BREAK, serial_byte, 7);
  digitalWriteFromBit(FUEL_WARNING, serial_byte, 3);
  // Enabled flags
  // Text length
  int text_len = Serial.read();
  // Followed by text
  if (0 < text_len && text_len < 127)
    for (int i = 0; i < text_len; ++i)
      while (Serial.available() == 0) // Wait for data if slow
        delay(2);
      if (serial_byte == 'a')
        //1
        digitalWrite(pinA, LOW);
        digitalWrite(pinB, LOW);
        digitalWrite(pinC, LOW);
        digitalWrite(pinD, LOW);
        digitalWrite(pinG, LOW);
        digitalWrite(pinH, LOW);
      else  if (serial_byte == 'b')
        //2
        digitalWrite(pinF, LOW);
      else  if (serial_byte == 'c')
        //3
      else  if (serial_byte == 'd')
        //4
      else  if (serial_byte == 'e')
        //5
        digitalWrite(pinE, LOW);
      else  if (serial_byte == 'f')
        //6
      else  if (serial_byte == 'g')
        //7
      else  if (serial_byte == 'h')
        //8
      else  if (serial_byte == 'i')
        //9
      else  if (serial_byte == 'j')
        //10
      else  if (serial_byte == 'k')
        //11
      else  if (serial_byte == 'l')
        //12
      else  if (serial_byte == 'm')
        //13
      else  if (serial_byte == 'n')
        //14
      else  if (serial_byte == 'o')
        //15
      else  if (serial_byte == 'p')
        //16
      else  if (serial_byte == 'q')
        //17
      else  if (serial_byte == 'r')
        //18
      else  if (serial_byte == 's')
        // R1
      else  if (serial_byte == 't')
        //R2
      else  if (serial_byte == 'u')
        //R3
      else  if (serial_byte == 'v')
        //R4
      else  if (serial_byte == 'w')
        // Neutral
      //sets range splitter LED's
      if (serial_byte == 'a' || serial_byte == 'd' || serial_byte == 'g' || serial_byte == 'j' || serial_byte == 'm' || serial_byte == 'p' || serial_byte == 's' || serial_byte == 'v')
      else
      if (serial_byte == 'b' || serial_byte == 'e' || serial_byte == 'h' || serial_byte == 'k' || serial_byte == 'n' || serial_byte == 'q' || serial_byte == 't')
      else
      if (serial_byte == 'c' || serial_byte == 'f' || serial_byte == 'i' || serial_byte == 'l' || serial_byte == 'o' || serial_byte == 'r' || serial_byte == 'u')
      else
