Pessoal, Estou vendendo dois motores e um controlador de velocidades novos, nunca usados. Comprei para um projeto que nunca saiu do papel e estou vendendo pelo preço praticado nos Estados Unidos +30%, o que não cobre nem as despesas de importação e frete. Frete por conta do comprador, os componentes estão em Belo Horizonte. Motores NPCRobotics NPC-T74 (2 unidades) R$ 973,00 cada Controlador de Velocidade RoboteQ AX2550 (1 unidade) R$ 1371,00 Descrição do Motor (curva de torque em anexo): A longer, more powerful version of the T64, it is a little faster and a lot more torque. This motor is a great choice for drive systems of 200-300+ pound robots. 1.469" diameter stub shaft with four mounting holes. The same size as the T64, but with 1" longer motor. 24V (can be run at 36) Reversible, Permanent Magnet 14.4 pounds 245rpm / 20:1 gear ratio Descrição do Controlador de Velocidades: Roboteq’s AX2550 controller is designed to convert commands received from a R/C radio, Analog Joystick, wireless modem, or microcomputer into high voltage and high current output for driving one or two DC motors. Designed for maximal ease-of-installation, it is delivered with all necessary cables and hardware and is ready to use in minutes. The controller's two channels can operate independently or mixed to set the direction and rotation of a vehicle by coordinating the motion on each side of the vehicle. The motors may be operated in open or closed loop speed mode. Using low-cost position sensors, they may also be set to operate as heavy-duty position servos. Obrigado! André
tabela NPC-T74.gif Tamanho: 4.9 KB Downloads: 717 veze(s) |
